Relay voltage spikes
Harald Kapp
13,743
13,743
A reverse diode is always a good idea, if only to protect the control circuit for the relay.
Powering on the 45W AC appliance (which is actually a fan) while the relay is already activated. Result: no click
Probably because the fan has an integrated filter to suppress the power-on surge, which may be bypassed if the fan is already in the on position and mains is switched by the relay.
Your observations make it rather obvious that the problem is not on the coil side of the relay, but on the contact side. I recommend you use a mains filter in the power supply to the fan, even better one filter in each of the supplies of the speakers and the fan.
cvicente
Sep 6, 2013
17
Sep 6, 2013
17
Ok...
So, just to make it clear (for me), the diode implementation is as I've referred in my last post, correct?
Couldn't I implement one, or does it have to be dimensioned depending on the AC appliance I'm connecting to the relay?
Carlos
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Nov 28, 2011
8,393
Yes, connect the diode as in the diagram in post #20.
The diode's current rating needs to be at least as high as the maximum relay coil voltage. Typically people use 1N400x diodes, though the 1N914 / 1N4148 is suitable for small relays.
Edit: I meant the diode's current rating needs to be at least as high as the maximum relay coil CURRENT.
Also, the diode's reverse voltage rating needs to be at least as high as the voltage applied to the coil. Generally both voltage and current ratings should be at least 50% higher than those minimums.
cvicente
Sep 6, 2013
17
Sep 6, 2013
17
Thank you Kris!
Thank you all for the help provided. I'll probably still investigate how could I implement some kind of power surge protection.
The idea is to plug-in any AC appliance up-to 16A (@230VAC), so I would be more confortable knowing that my circuit would be already prepared to deal with surges generated from whatever AC appliance is connected to the relay.
Carlos
cvicente
Sep 6, 2013
17
Sep 6, 2013
17
Thank you Harald,
But I was actually thinking on giving it a shot with varistors. I still have a lot of study to do on the matter, but as far as I understood, that's pretty much the way to go:
Varistor and a fuse when overheating becomes a problem.
Or am I waaaayy of?
Carlos
Harald Kapp
13,743
13,743
A varistor will limit voltage spikes. At this point we do not know whether it is spikes that cause the "click". It can also be a sudden drop in voltage due to the inrush current of the load. In fact, I think this is far more likely. In this case a varistor is of no use. You need something to filter out the harmonics that are caused by the voltage sag.
cvicente
Sep 6, 2013
17
Sep 6, 2013
17
Oh... I didn't think of that... but we're talking about 45W@230VAC, so if my calculations are correct that means that it will draw a max of 200mA. Would that be enought to lower the voltage that much to be the cause of the "click"?
And, since we're at it, how can I know for sure what's really happening (I'm not doubting you, just wondering, how such a thing can be investigated)?
Carlos
Harald Kapp
13,743
13,743
That's 200 mA in steady state. At turn-on, the motor is not yet rotating. A motor in standstill cannot generate a counter EMF. It look like a very small resistor to the power supply at that moment (use your Ohmmeter to verify). Therefore a comparatively huge inrush current will flow.
cvicente
Sep 6, 2013
17
Sep 6, 2013
17
Do you mean measuring the resistance of the fan? If that's the case, won't I have to get the fan motor uncovered?
Carlos
Harald Kapp
13,743
13,743
You don't have to.
Disconnect the fan from mains.
Put the switch in the ON position.
Measure the resistance across the pins of te mains plug.
This way you measure the resistance as seen by themains outlet.
cvicente
Sep 6, 2013
17
Sep 6, 2013
17
Yeah... I end by doing exactly that, although I just wasn't sure if that would be the way to go!
The result: 571 ohm.
cvicente
Sep 6, 2013
17
Sep 6, 2013
17
Ok, so... In the middle of all this great advises (thank you all, once again, for all your patience) I've just realized something that incredibly I just noticed this night.
So... don't you hate me for this... but... I just realized that the power cord, which is powering up my circuit and the fan itself is already connected to a power strip with surge protection... so... I guess what Harald said in a past post:
Makes even more sense now, right?
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
Having the amp and the fan sharing the same power strip isn't helping eliminate your problem. It's more likely exacerbating it.
Chris
