Can anyone help me out in trying to figure out how to test a S60D125 relay? I'm not sure what I should be reading on which points, how much voltage and amps to apply to which points, etc. Any help is greatly appreciated!
No simple way to test it. You could apply an input to the 'coil' of the rated 7 - 30 volts and be sure it draws a little current. May be as low as 1 mA. The output side, you will need to provide an AC voltage and a load, then see if it switches.
