Relay switch help
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
That's the contact ratings. A load of 12v is less than 220v so your fine provided you don't exceed 15 amps.
No minimum.
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
So you are saying that even 3.3volts will work as long as it wont exceed 220 volts because it is that maximum voltage?
Yes, maximum ratings of the relay contacts.
The coil is 5v but the contacts can be from 0 to 220v. Think of it as a light switch.
