About 20 years ago, a friend (who I know longer have contact with) designed some circuitry to control my heating system. It involved the use of relays etc to switch things on and off. One of the relays buzzes like mad (suddenly). When I replace it with a new identical relay, the same thing happens to the new one. The coil side of the relay is 24V DC.
Opening up the box, I can see a circuit board with what looks like 3 diodes and a bridge rectifier. I can see a supply for 23V AC from a transformer. I think the diodes and the bridge rectifier are some sort of power supply circuitry to make the AC into DC. I am no expert though. Does this make sense? Is it likely that one of these components has failed and that AC is getting to the relay to cause the buzzing?
There is no obvious sign of failure or problems with the existing components.
I am up for replacing all the components but I am struggling to identify their specification. I can take a photo later and post if that helps.
