Relay Alternative
Hi.
I'm building an project to control house devices through PC using
Interface Card from Vellman K8000
I will order SW, which give +5V to Digital output channel this charge
will drive the relay to close, i need another reliable technique
instead of relays somthing that can power high volatge devices such
Air-Condition and it can be signaled through +5V.
Is QBAR good? can it pass 220 volt, or Relays is the only one?
Is relay reliable?
Thanks.
Hi.
Is relay reliable?
Thanks.
Hello,
I believe a relay or a triac may be used for this.
Ian Coolidge
Undergraduate Student
H
Hlrsr
Hi.
Is relay reliable?
Thanks.
Why not using TRIAC or Solid State Relays (instead of ElectroMechanical)?
Regards
GM
D
David L. Jones
Hi.
Is relay reliable?
Yes, relays are reliable, they are used for mains swiching all the
time. You do need a proper relay with suitably mains rated contacts
though.
But if you didn't know this already then maybe you shouldn't be
touching mains rated stuff just yet...
If your air-con has an IR remote control then you can control it with
the PC via an IR module - no mains wiring required.
Dave :)
