Dear Forum
I have a 390 Volts battery (in-from) a EV car and charge this during the day time with solar panels. I use the AC charger that comes with the car (1771 plug) - no problem - I can charge the battery every day.
At the end of the day the battery has 396 Volts and a capacity of 24 kWh.
The solar system is grid tie type and the inverter can accept DC voltages up to 850 Volts DC on the string inputs.
In the evening I use the battery to power the house, but the inverter sends most of the power into the grid, because my battery can supply a lot of energy.
I need a controller to 1. adjust the power (current) delivered by the battery to minimize the inverter output or
2. adjust the voltage from e.g. 392 Volts to 180- 380 Volts.
This should be done with PWM to have the least losses. Anyone a schematic or hint of components to use? Thank you.
