Regulator circuit needed
Discussion in 'General Electronics Discussion' started by macca, Dec 14, 2009.
  1. macca
    macca
    Dec 14, 2009
    hi there
    im just taking a intrest in electronics im after a circuit using the 78s12cv regulator
    i have found a circuit on the net what do you think about it
    [​IMG]
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Yes, that's a standard setup, but C2 should be 0.33uF and C4 is not absolutely neccessary - according to the datasheet.
    T1 must be rated at least 12V & 2.8A (34VA) and C1 must be rated at least 25V, if that was your next question.
  3. akashbindra1431
    akashbindra1431
    5
    Dec 16, 2009
    use 1N4007 diodes ,its better!
  4. neon
    neon
    1,325
    Oct 21, 2006
    If you are going to add big capacitor on the output put a diode across the regulator
