Regarding XTR110 V to I converter
Discussion in 'Electronic Design' started by asm, Apr 7, 2007.
  1. asm
    asm Guest
    Can any one tell me whether XTR110 V to I convereter is meant only for
    DC voltages or works fine wid AC voltages as well ...
    Regards,
    Asmita
  2. Tom Bruhns
    Tom Bruhns Guest
    It's in the current data sheet from the TI web site. See the spec for
    "dynamic response settling time" for instance. The input voltage
    should be offset from zero, a suggested by figure 6 in the data
    sheet: if the input voltage range is 0 to 10 V for 4 to 20mA output,
    then you can input a 10V p-p AC signal if you bias it with +5V DC, so
    it swings from 0 to +10V.
    Cheers,
    Tom
