Hi everybody !
I want to design automatic water pump controller.
So please help me with circuit diagram and designing.
Water pump controller should control the water pump as follow
Basically it should have two modes of operations
1. Manual
2.automatic
In automatic mode
1. it should start the pump whenever there is power supply on
2. It should stop the pump when there fault in power supply
3. It should again start the pump when the power supply is ok
4. It should stop the pump when ever there is dry run of pump.
5 It should again start the pump when pump gets filled with water.
1. Manual
2.automatic
In automatic mode
