regarding synchronizer design
Discussion in 'Electronic Design' started by esbalu, Apr 28, 2005.
  1. esbalu
    esbalu Guest
    Can some one tell me how to calculate the number of synchronizer
    stages when I want to transfer a signal from clk domain A to clk
    domain B...?
  2. The driving consideration, if you try to engineer the solution,
    will be how often metastability causes an output error from
    the synchronizer. This has been treated theoretically quite a
    bit. I suggest you do a web search on the words:
    metastability probability synchronizer. Here is a link:
    http://www.google.com/search?hl=en&q=metastability+probability+synchronizer&btnG=Google+Search
    Of the hits that show up early, at least this one looks good:
    http://www.interfacebus.com/Design_MetaStable.html
  3. Fred Bloggs
    Fred Bloggs Guest
    You must be getting tired? Posting a simple Google link rather than
    cut-and-paste'ing the concepts, crudely, and representing them as your
    own, as you've done numerous times in the past...Good boy, poser.
  4. John Larkin
    John Larkin Guest
    Two.
    John
  5. Ken Smith
    Ken Smith Guest
    Or perhaps zero if you don't mind the glitches when the signal changes
    state at just the wrong time.
  6. John Larkin
    John Larkin Guest
    If the signal changes state at the clock edge of the receiving system,
    that's OK; a 1 or a 0 is just as good when it was changing anyhow. The
    usual concern here is metastability.
    John
  7. Ken Smith
    Ken Smith Guest
    usual concern here is metastability.[/QUOTE]
    metastability == glitches in this case. You get a glitch just after the
    clock edge when the metastabiltity happens. If the rest of the circuit
    doesn't care about the glitch, you can just ignore the problem.
