Regarding semiconductor equivalence...
Discussion in 'Electronic Components' started by Armen Forget, Oct 14, 2003.
  1. Armen Forget
    Armen Forget Guest
    Hi. This has confused me for some time now. Let's say I have x number
    of general purpose NPN BJTs (or any other semiconductor device). Their
    model #s seem strange (to me) and are relatively hard to find. So I
    checked their NTE equivalents through their catalog, and they're all
    the same: NTE123AP. Now, the 2N3904 (which I've got plenty of) also
    has the SAME NTE code! Does this mean all models are equivalent? Can I
    just substitute the 2N3904? Or does NTE make their devices superior to
    a whole set of devices to increase compatibility?
    Someone please help. I'm tired of looking for odd models of
    semiconductor devices. And thanks for taking the time to read this
    boring letter. :)
    Armen
  2. No, you cannot. The NTE is supposed to be equal or better. For
    instance (only as an example, may not be the actual values), Your
    unknown device may have a minimum current gain of, say, 200, typical
    of 250. The NTE data may show the NTE123 substitutes, but it has a
    minimum gain of 200, typical 300, which is fine for substitution with
    yours _and_ the 2N3904. But the minimum gain of a 2N3904 may be 120,
    typical 200. So even tho it seems to be a sub, the minimum gain would
    be much less than your unknown device.
    So your substitution procedure, in general, is not a valid method.
    However, with more detailed knowledge, such as the circuit that it's
    going into, etc., you might be able to make a good estimate of whether
    or not this kind of sub will work.
    We've also pondered this kind of thing ourselves. Some of us have
    gone thru that learning process and found out the foibles in it. So
    it's good to ask, so you can find out before, and save yourself the
    trouble.
    @@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@,@@[email protected]@[email protected],@@[email protected]@[email protected]@[email protected]@
    ###Got a Question about ELECTRONICS? Check HERE First:###
    http://users.pandora.be/educypedia/electronics/databank.htm
    My email address is whitelisted. *All* email sent to it
    goes directly to the trash unless you add NOSPAM in the
    Subject: line with other stuff. alondra101 <at> hotmail.com
    Don't be ripped off by the big book dealers. Go to the URL
    that will give you a choice and save you money(up to half).
    http://www.everybookstore.com You'll be glad you did!
    Just when you thought you had all this figured out, the gov't
    changed it: http://physics.nist.gov/cuu/Units/binary.html
    @@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@
