regarding Integrate and dump filter and Early-Late Gate Correlator
Discussion in 'General Electronics' started by viswanath, Jul 8, 2004.
  1. viswanath
    viswanath Guest
    I wanted to know how an integrate and dump filter acted as a low pass
    filter. I have come across literature where instead of a low pass
    filter an accumulate and dump(integrate and dump) has been used. I was
    wondering how it would result in filtering action. Could anyone throw
    some light on this subject?
    I had another question too: I wanted to know how exactly an early late
    correlator works during pn code synchronization. Precisely how one can
    change the clock rate. I wanted to know if we need to change the
    frequency of the clock or keep the frequency constant and just shift
    the clock when we say advance or retard the clock.
    I would really appreciate if someone could help me on these two
    questions.
    Looking forward to your replies,
    Thanking You,
    Viswanath
  2. Tim Wescott
    Tim Wescott Guest
    If you make a running average filter, where y_k = 1/n * sum(x_(k-n+1)
    .... x_k) then it will have a lowpass response (really sinc(f), but
    that's kinda lowpass).
    If you only sample y_k every n points then you may as well use and
    integrate and dump.
    QED.
    Do you want to know what the correlator does, or what you do with the
    output? The correlator lets you know where the clock should be. How
    you change the clock rate depends on your technology (but you would use
    a VCO in an analog circuit). You want to change the clock rate so
    you'll still be correlated if your signal suffers dropout.
  3. Consider that an integrate and dump filter can be realized as a FIR
    with a rectangular impulse response. The filter frequency response
    is then the FT of a rectangular function, in other words a sinx/x
    frequency response. That's a low-pass filter, although not a very
    good one.
    Eric Jacobsen
    Minister of Algorithms, Intel Corp.
    My opinions may not be Intel's opinions.
    http://www.ericjacobsen.org
