Refrigerator Not cooling
Discussion in 'Troubleshooting and Repair' started by vrak, Dec 8, 2014.
  1. vrak
    vrak
    5
    Dec 4, 2014
    Hi all any body help me
    Why refrigerator not getiing cool
    Light in side frige is glowing
    Compresser also running
    Please provide your suggestion how to check fridge step by step
  2. duke37
    duke37
    5,364
    770
    Jan 9, 2011
    If the compressor is running but not working it is possible that the system has leaked and gas has been lost. Most refrigerators have a sealed system but loss of gas is common in air conditioning systems in cars where the drive is through a rotating shaft.
  3. chopnhack
    chopnhack
    1,573
    354
    Apr 28, 2014
    Does the compressor run continuously, or does it seem to cycle on and off? If cycling, how long does it stay on/off?
  4. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    Did you check the accumulated dust and grime coating the heat-exchange coils, usually on the back (some on the bottom of the fridge?
    Cleaning those coils may go a long way in solving your problem.
  5. elebish
    elebish
    177
    12
    Aug 16, 2013
    Most refrigs use a thermistor near the compressor that heats up under current flow to the compressor and changes resistance. This thermistor looks like a thick disc that is very fragile and breaks easily and is generally inside a cover or housing. It's made of carbon and fits between 2 spring contacts. If it is broken or cracked, that may be your problem. Ensure that you replace it with a like item with the same resistance. Ed.
