flippineck
- Sep 8, 2013
- 358
- Joined
- Sep 8, 2013
- Messages
- 358
I have a board which was built around 2000. It's a control board for a boiler.
It has some kind of microprocessor (size and format of a Z80), and a bunch of assorted discrete passive components and semiconductors - some surface mount, some with thru hole wire leads.
I'm suspecting the fault I have with it might well be due to dry solder joints - it works fine at high room temperatures especially if you give it a good hard slap, but when it's cold it misbehaves. Also a google search indicates many others have experienced faulty soldering on these particular boards.
Having looked good long and close at the track side, I fancy I can see a few dark hairline rings around a few of the component leads where they sit in their solder bobbles.
So anyway.. I had success fixing an Xbox a while ago by reflowing the board using a kind of non-corrosive liquid flux in a pen, and a glorified high temperature hairdryer. ISTR the webpage i was following instructed me to use the pen to get the flux right under the main chip on the xbox's pcb, then heat the whole board up with the blow gun until the solder remelted.
I was extremely sceptical that it'd work (all through my 70's & 80's childhood all I ever seemed to hear was 'heat kills semiconductors' 'always use a clip on heatsink when soldering' 'only use the briefest touch with the iron') so I thought the wholesale 'cooking' of the board would just kill it. But it was a dead board anyway so what was to lose. I was amazed, it worked..
So I was going to try doing the same with this boiler board but.. what would be the best flux to use, where to get it, does it need washing off, what with if so.... memory not so good these days lol.
