References for PIC microcontroller programming for sensors
Discussion in 'Electronic Design' started by Shaddy Daddy, Oct 31, 2003.
  1. Shaddy Daddy
    Shaddy Daddy Guest
    Does anyone have any references for PIC microcontroller programming
    for sensors (ie such applications as light detection /laser detection)
    Thanks!
  2. Luhan Monat
    Luhan Monat Guest
    Shaddy,
    Sounds like a no-brainer to me. Just connect the sensor to an
    appropriate load resistance and feed an a/d input on the pic. You
    should find lots of reference listings for using the a/d on Microchips
    website.
  3. John Fields
    John Fields Guest
  4. Its output is a square wave, so instead of the A/D, I'd put the timer into
    'counter' mode, use the timer input pin to count ticks for some interval,
    and then read out the result from the timer register. Alternately, a
    frequency to voltage converter IC would work to transform its output into an
    analog voltage, so you could use the A/D.
    I'm guessing you were just pointing out the limitations of using the A/D for
    every sensor job.
    I agree.
    Regards,
    Bob Monsen
  5. How would you connect something like a TI TSL245 to a PIC's ADC input?
    It has a frequency output, so I'd google for 'pic frequency meter'.
    Wouter van Ooijen
    http://www.voti.nl
    PICmicro chips, programmers, consulting
