C
CG
I hope someone can help me, for I know not about such things! I have
a LEDSupply.com Micropuck driver for the Luxeon 1 watt LED "Star". I
must run it off of four (4) NiMH "AA" cells (1800mAh) the produce
something on the order of 5.6v (4.8v nominal).
I have a problem. Though it will run amazingly well on this set up,
the micropuck driver gets very hot only after a few seconds. I
figured this would happen. My plan was to drop the voltage of the AA
cells to the maximum operating voltage of the micropuck; 3v. However
(and here is where my limited knowledge of such things haunts me) when
I successfully drop the voltage to 3v by using a resistor (as tested
on my multimeter) the LED will not illuminate. No matter how small a
resistor I use, no light.
I have to run the whole thing on the 4.8v, because it also runs
another LED component that requires this.
How can I do this? Is there another way to drop the voltage to 3
volts so I can still run the driver/LED without overheating it? I am
pretty sure if I continue to overdrive the driver it will fail. Any
suggestions? And thanks in advance...
Chris the Caver
Chris the Caver
