M
mike
PeterD said:Or use the defrost cycle!
When I ask a question on line, I go to great lengths to describe the issue
in detail to keep the discussion from running off in all directions.
It rarely works, but I keep hoping that people will actually read the
info before shooting from the hip.
With this, and every other low-end non-inverter microwave oven I've ever
encountered, the power is adjusted by pulsing the magnetron in bursts
of approximately 15 seconds followed by an off-time required to get the
average power you programmed.
The RELEVANT number is the 15 second MINIMUM on-time. Doesn't matter
what buttons you push, you can't get an on-time less than 15 seconds unless
you program a single burst that's shorter.
If 15 seconds is long enough to boil the liquid in part of the payload,
defrosting can make a mess of things.
In this case, the "defrost" button has some algorithm that they don't
disclose
and I've been too lazy to reverse-engineer, but the minimum on-time
is still about 15 seconds.
It's a fundamental property of the design.
