There is no circuit, I had a broken amp, and I was planning to convert it as labo psu.
The circuit I've got was using a 2x15V psu hooked up to have 30V.
my amp psu ended up to be 2x24 or 1x48. (if I hooked it up that way)
Since I really do not need to get as as high, I was hoping to use the 2x24 AC and convert it to DC wich will be higher then and then build the "labo part". I have a lower specced labo psu that gives 30V at 2 amps, wich should be enough at that voltage
I already switched the unit to 220V to get some more out of it instead the 240V to fool the coil.
As far as I know one two diodes out to be enough
NC (output 48V AC)
--->--- plus (output 24V AC)
wired ---- (as minus)
--->--- plus (hooked up with other plus)
I was not sure so I just thought let's be sure and have this
-->--- plus (plus hooked up with other plus at DC )
---<-- min
--->plus.
Then my ratings in my first circuit where 3 amp diodes, and although I probably never get there I wanted to have 9 amps.
Anyhow I have used two diodes to make sure now.
I hope this make scense.
Anyhow this circuit is the one (with one cap missing) I was hoping to use finally and continue work on another separte board to build the labo psu.
It's the same but it uses two diodes per wire instead of 3.
[Images removed -- causing problems]
It is overdimensioned, but I want to build robust. The module should be able, if I get my hands on an heavier coil to be used again.
