M
malcolm walker
When i measure the input and output of a bridge rectifier using a two
channel oscilloscope i loses the negative cycle of input and negative cycle
of out.
The input signal is supplied by a frequency generator about 10 volts, 100 Hz
and used 1N4005 diodes.
Could someone explain why the negative cycle is killed off when i connect
the scope lead to the output of the bridge rectifier.
of out.
