D
Dave VanHorn
MFM works like this:
Sounds like what is used on bank cards, we always referred to it as F-2F
I never translated our rates into BPS, but the card speeds were pretty
highly variable.
I wouldn't be surprised if we went up around 2400BPS.
The limit, once we figured out that you can't treat the head as a voltage
source seemed to be the user's ability to keep the card in the track.
Differing phase delay at different frequencies, will also give you some
pretty interesting grief.
For each bit time, at t = 0 there is an edge (toggle whatever level
the output is at the time.) If the bit value at 1, at t = 0.5 there
is another edge; otherwise the level stays the same.
The ABC80 used 700 bps; the later 800 machine used 2400 bps but the
same modulation technique.
highly variable.
If you want higher bit rates you should start to consider some of the
techniques used by modems, like quadrature decode and multilevel. The
biggest issue about using those on a cassette tape is that you have
nonlinear distortion due to speed differences; those are hard to
analyze in the context of especially quadrature decode. An
alternative is to use digital techniques which put in synchronization
pulses in fewer places (if you remember RLL hard drives, that was one
such technique.)
