P
ptek
Hi !
I have a nvidea fx5200 graphic card with TVout (composite video) and I
trying to record some PC videos to a VCR.
By now I succeded in recording it's video output to the VCR via SCART
conector :
As we can see on http://www.hardwarebook.net/connector/av/scart.html
the 20 and 17 pins on the SCART are what we need to record the
composite video from the graphics card.
Now it tried to record the audio ... What I did was to wire the 'Audio
In Left + Mono' SCART pin 6 to the left audio signal from my soundcard
(SB 128) and wire also the 'Audio Ground' SCART pin 4 to the
correspondent audio ground on the soundcard (I didn't bother to wire
the right audio channel to the SCART for now ...)
Strangely (or not) no audio was recorded on the VCR (the video was OK)
.... But I managed to sucessfull record audio from another audio source
(line-out from a CD walkman )
Why I can't record audio from the soundcard and have no problems on
recording from the walkman CD player ?
I'm looking to the impedance field on the table for pin 6 (look for
the link above) '>10k ohm' . Should I include any resistor between
the soundcard and the SCART pin 6 ?
I think i'll try this now ...
if you had spotted the problem, please help
Thanks !
btw: is this the correct newsgroup to post this kind of question ?
conector :
Thanks !
