Record Player power
S
Simon
I'm considering buying a record player from a 2nd hand shop. The
problem with it is it must have been from an integrated hifi system
and only has a 6-wire connector (no phono jacks or ac plug).
I would guess the 6 wires would be:
- right audio
- right audio gnd
- left audio
- left audio gnd
- power
- power gnd
It's a Panasonic deck. Does anyone have any info on this 6-wire (grey)
connector? Or what sort of voltage a record player would use? Is it
kind of standard or ?
Any advice greatly apreciated.
Simon
K
Kalman Rubinson
- right audio
- right audio gnd
- left audio
- left audio gnd
- power
- power gnd
Trace them. The signal wires should show contuity to the cartridge
and the power leads to the motor and/or PS.
Kal
M
Mark
Most turntables run on 120 VAC.
Mark
The truth as I perceive it to be.
Your perception may be different.
Triple Z is spam control.
M
Mark D. Zacharias
I would pass on this one. There's lots of better table around which have
ordinary connectors and get their power from the wall.
Ebay for example sell lots of turntables at reasonable prices every day.
Mark Z.
A
Asimov
"Simon" bravely wrote to "All" (29 Sep 03 04:09:11)
--- on the heady topic of "Record Player power"
As you say those plugs are supposed to go into an integrated stereo main
unit and aren't very easy to adapt to a component type stereo system.
These types of turntables may have a preamp IC in them but not usually
RIAA corrected. Best get a different type of TT to avoid the headache.
Si> From: [email protected] (Simon)
Si> I'm considering buying a record player from a 2nd hand shop. The
Si> problem with it is it must have been from an integrated hifi system
Si> and only has a 6-wire connector (no phono jacks or ac plug).
Si> I would guess the 6 wires would be:
Si> - right audio
Si> - right audio gnd
Si> - left audio
Si> - left audio gnd
Si> - power
Si> - power gnd
Si> It's a Panasonic deck. Does anyone have any info on this 6-wire (grey)
Si> connector? Or what sort of voltage a record player would use? Is it
Si> kind of standard or ?
Si> Any advice greatly apreciated.
Si> Simon
.... Just a little force field zap.
G
Gary Tait
Whereas On Mon, 29 Sep 2003 20:19:22 -0400, Mark
But not this one. I have a stereo that came with a turntable that ran
from a 15VDC supply from the stereo unit, although it use a
traditional RCA plugs for audio, and a coaxial DC plug for power.
