Recommendations for 'Single supply' single op-amp for LF / DC appswith rail-rail I/O ( voltage follo
Discussion in 'Electronic Design' started by Eeyore, Jan 19, 2010.
  1. Eeyore
    Eeyore Guest
    Supply = 12 or 15V
    10kHz bandwidth would suffice !
    Will only be used as a voltage follower
    I/P and O/P must go to GND ( V+ not such an issue )
    I input bias uncritical, i.e. bipolar fine. Source Z < 2k
    Vos < 3 mV would be fine
    Must be through hole ( ideally )
    Suggestions ? Not my normal area !
    Criteria include low cost, multiple sourcing and good stock levels
    Thanks, Graham
  2. Check the TLC2272.
  3. Rich Webb
    Rich Webb Guest
    LM6132 is a dippie, nice R-R I/O (actually, a bit outside the rails on
    inputs, output not quite there for largish loads), not quite your Vos
    spec at guaranteed max, and maybe little tight on phase margin (though
    it is spec'd for unity gain applications).
