Jon Kirwan
Get a Rigol color digital scope. DS1052E is good. Under $400.
Rigol dropped the price on their DS1102E to under $400, ...
more than 1/2 year ago, I think.
Jon
Yeah. $399.
Of course, I knew. When it dropped, I immediately bought one
from a business that had dropped it even lower still, to
$349.
This isn't a bad starter..notbob said:Are you going to reveal this magical place?
I found half doz prices online and none were below $395USD.
nb
The real trick is finding a 1052 50MHz model. I've seen 'em fer
$329USD at Rigolna.com (north america). Then, you jes do the software
upgrade to 100MHz! If I'm not mistaken, it's the exact same hardware,
right down to the same chip numbers. There's an entry on D Jone's
EEVblog website that talks about it. I may have misinterpreted what
he was saying. Ima geezer.
True however, 2 of the guys I work with did that and I decided to get anotbob said:The real trick is finding a 1052 50MHz model. I've seen 'em fer
nb
As I get more advanced at creating circuits, I can see the benefit to
owning an Oscilloscope. I'm on a fairly tight budget, and was hoping to
get a recommendation on a cheap oscilloscope that is "good enough" for
hobby work. I've used one at school years ago, which probably had more
bells and whistles than I would ever need.
What features are essential for a hobbiest? What can I do without? Any
particular brands that are cheap but reliable?
Thanks for suggestions,
Daniel.
But is that all that different from the old Tek scopes with endless knobs?Nowadays the benchtop digital scopes have the usual knobs, volts/div,
time/div, positions, trigger level. They do have menus for stuff like
ac/dc, trigger slopes, that sort of thing. The Rigols are pretty easy
to drive.
In the early days of digital scopes, some had, like, 4 buttons and all
menus. We domo'd one HP scope that nobody could get to do anything.
The most valuable button on my Tek scope is "default setup" which,
basically, means "get me the hell out of here!"
We've had questions here over the years, people can't get their scopes to
work, and the answers are usually things like make sure the knobs are set
right.
I bet I remember that one. Two stacked boat anchors, one a 10-Ms/s
digitizer, the other a display. You had to drill down two menu levels
to set the vertical gain.
I got it off the IBM corporate surplus list, and within an hour it was
out in the hallway to be taken away and thrown out.
I'm pretty fond of my 475 and 2467. You can see stuff that's invisible
on most digital scopes. They also don't alias, which Simon found
helpful this summer. (I'll be integrating some of his LPC1769 code into
my noise canceller design this week.)
AKA RTFM.
Tek analog scopes were made for *engineers*, who used to know at least
something about how they worked.
No, it's a matter of going through all the knobs to see which one is set
wrong. The manual won't help one bit.
Don't be an ass. You still need to go through all of the settings to see
which one is messed up. With no trace, it's not obvious which one it is.
I had a Tek 4-trace, 1GHz B/W, color, TDS something-or-other, that I
never fully got the hang of. My digital 'scopes are now all HP.
My eBay success rate is probably 92%, averaged over several dozen
instruments. The exceptions have been mostly due to poor packing.
On Sun, 19 Aug 2012 12:38:16 -0700, Fred Abse wrote:
I grew up with analog scopes and found the TDS learning curve to be
almost flat. Before long the instrument was just like a natural
appendage. I never could get the hang of the Agilent scopes.
'Seems like the least little operation required lots of time looking
at the manual. Feh.
Agilent learned how to make scopes about a dozen years ago, right around
the time that Tek forgot.
When I was at IBM, around 2006ish, the Tek guys demoed a 10-GHz scope
that had about 8% overshoot on the step response.
It was a really sad experience, having to explain to *Tektronix factory
engineers* that a scope lives and dies by its step response.
The 7-GHz TDS7704 I eventually bought (a demo model) was much better,
but still not what it should have been.
They do seem to have wised up considerably in the interim--I had a demo
of their nice MSO-spectrum analyzer combo, which I might buy if a couple
of contracts come in. Unfortunately the spectrum analyzer part doesn't
have that great close-in phase noise, but the three-domain capability is
very powerful.
And the new ones don't run Windows, huzzah!
