Recommendation for a "common" 3.3V LDO regulator?
Discussion in 'Electronic Basics' started by John, Dec 18, 2007.
  1. John
    John Guest
    My head is absolutely spinning after trying to find an easily
    available (i.e., multiple source) "generic" LDO voltage regulator to
    power a PIC and a few components. Just too darn many choices.
    The specs are:
    - Max. output current = 75mA (probably only 50mA)
    - Output voltage = 3.3V
    - Lowest input voltage = 3.6V
    - Highest input voltage = 5.1V
    - DIP package would be nice (for prototyping), SOIC OK.
    - Lower noise is nice as I'm using a PIC ADC input.
    Any favorites of yours that you might recommend?
    Thanks!
    John
  2. DJ Delorie
    DJ Delorie Guest
    The one I use most is Microchip MCP1700 (SOT23 and TO92, although I
    only use SOT23). 178 mV dropout (i.e. 3.5v min for 3.3v out), up to
    6v in. 250mA out depending on heatsink and package.
    I also have some generic TO220 linears.
  3. -----BEGIN PGP SIGNED MESSAGE-----
    Hash: SHA1
    I second that - the 1700 seems to work great for everything I've done.
    It'll even work without a cap on the output (don't ask how I know that
    ;]), though I don't suggest doing it on purpose!
    If you're getting PICs you may as well choose the parts from the same place.
    Brendan Gillatt
    brendan {at} brendangillatt {dot} co {dot} uk
    http://www.brendangillatt.co.uk
    PGP Key: http://pgp.mit.edu:11371/pks/lookup?op=get&search=0xBACD7433
    -----BEGIN PGP SIGNATURE-----
    Version: GnuPG v1.4.3 (MingW32)
    iD8DBQFHaS0NkA9dCbrNdDMRAtzwAJ48rknBbDxOljp4+tQmVqdAxQWQ7QCgoghc
    K3u/isAGtl75IeHT3Na43ME=
    =U5bs
    -----END PGP SIGNATURE-----
  4. John Larkin
    John Larkin Guest
    LP2985 is nice. It's stable with ceramic output caps.
    John
  5. John
    John Guest
    Nice parts, thanks for the recommendations!
    I've ordered samples of each to play with. :)
    John
