recommend a soldering station
andrewjs18
Dec 18, 2013
3
Dec 18, 2013
3
Hi all,
first, I hope this is posted in the correct area as it seemed to be the best place to put it.
I'm new to the world of electronics and I'm hoping you folks can recommend a decent soldering station to be used for DIY projects and circuit boards. I work in IT so the occasional motherboard repair might be in order. I also need to replace a few burned out LED bulbs in my Buick's various gauge clusters.
anyhow, what do you folks recommend around the $75 range?
Andrew
GreenGiant
Feb 9, 2012
842
Feb 9, 2012
842
just above your $75 number there, but this one is one of the most reliable, tried and true solder stations I know of.
My father has 2 (one for use upstairs, one for use in his basement workshop) the last company I worked for had 3 of them (they moved around a lot and got dropped from time to time).
I would say well worth the $88 since its going to last you forever, just make sure that you get some tips for it.
andrewjs18
Dec 18, 2013
3
Dec 18, 2013
3
thanks for the recommendation.
the only station I've been looking at is this one: http://www.amazon.com/Hakko-FX888D-23BY-Digital-Soldering-FX-888D/dp/B00ANZRT4M
I like that one a little bit more because of the digital readout.
andrewjs18
Dec 18, 2013
3
Dec 18, 2013
3
hi all,
sorry to bump my very old thread.
I bought the hakko fx888d soldering iron a while back. this will be the first time I'm going to use it, but I had a few questions first.
1- which type of solder should I pick up?
2- I believe a new soldering iron needs its tip tinned? if so, are there any instructional videos that you prefer on doing this properly?
thanks!
