rechargeable batteries
Z
zooz
Hello
How can I charge a rechargeable battery in the lab, what's the
'reverse connection'?
P
Phil Allison
"zooz"
** You use the normal connection - ie positive battery terminal goes to
positive terminal of the charger.
But the charger has to have higher voltage available than that of the
battery.
Plus, you need to add a resistor in series with the DC supply to limit
current flow.
The charging reaction commences immediately and the voltage on the battery
can be seen to gradually rise on a sensitive volt meter.
What happens next depends entirly on the kind of battery, its size and the
current flow you set up.
....... Phil
Z
zooz
"zooz"
battery.
current flow.
...... Phil
i have another question,
-i have to charge two 1.2 v batteries, do i connect them in series and
then the free positive terminal to the positive of the charger and so
the negative?
-and how do i know the limit of the current?
thaks
P
Phil Allison
"zooz"
"Phil Allison"
** No surprise......
the negative?
** Series is OK.
** Gotta know all about the particular cells for that one !!
The maker's web site usually has the info - or it may be written on the
cell's jackets.
....... Phil
John B
Hello
WTF. Go and buy a $5 charger from WalMart.
Next question.
John Devereux
zooz said:
Hello
What sort of battery (NiCd, NiMh, Lithium, lead-acid, etc)?
D
D from BC
I'm wondering if any of those battery chemistries can be safely
charged by temperature monitoring..
Assume one doesn't have datasheets and doesn't care about charging
damage..(Survivor Man does battery charging... )
I dunno...let's say charging up to an external battery temp of 40C???
D from BC
