Receiver loses one channel
Discussion in 'Electronic Repair' started by alpha_uma, Jul 20, 2004.
  1. alpha_uma
    alpha_uma Guest
    I have an old Toshiba SA-5000 receiver. It has two "Tape" inputs. "Tape1" is
    having a problem. More often than not, it always loses the left channel when
    the receiver is powered up. If I switch the selector knob back and forth
    quickly a few times between "Tape1" and "Source", the left channel might
    come back OK, but then after a while, it will lose the signal again.
    Everything else seems to be working fine.
    Could it be just a simple oxide-related "contact" problem at the selector
    knob, or is it more likely to be caused by some failing transistor(s) and/or
    capacitor(s)? Could you recommend a good brand of contact cleaner?
    I have no experience in repairing amplifiers and receivers, but I do have
    some working knowledge with electronics--mostly digital computer circuits. I
    would appreciate any suggestion as to possible causes of this type of
    circuit misbehavior to get me in the right troubleshooting direction.
    Al-U
  2. Mark W Smith
    Mark W Smith Guest
    You are most likely right about the contact problem. Clean all controls with
    a good spray cleaner. I have found that the older units need the real good
    stuff like Caig De-Oxit Red. It's a little expensive, but the cheaper stuff
    doesn't last very long.
