M
Michael Noone
Hi - I need to connect two PCBs together. They will move relative to each
other constantly. I'd like to find a fine pitch (maybe 1mm or so) flat
cable to connect between them - preferrably one that will be able to
tolerate this movement. I should mention this is not a production item -
under 10 of these will be made. I'd like it to be some sort of flat cable
that can easily have connectors added on to it.
So I see two major possibilities for connectors. The first I think is
called "insulation displacement connectors" - the kind of connector that
punches into a ribbon cable. The other possibility I see is what you often
see connecting the laser in an optical drive to the main board - where
there is a clear cable and the connector is just a stiffer bit on the end
of the cable. Is it possible to make such cables? Or does that have to be
done by machine?
Any suggestions? Thanks!
-M. Noone
done by machine?
-M. Noone
