Recargeable Battery
Discussion in 'Electronic Basics' started by Nikki, May 3, 2005.
  1. Nikki
    Nikki Guest
    Does anyone know if there is a place where someone can get the batteries
    for the Dewalt drills refurbished.
    Nikki
  2. Tom Biasi
    Tom Biasi Guest
    Crack open the case at the seams and replace the NiCads with ones with tabs.
    Super Glue the case back.
    Tom
  3. Chris W
    Chris W Guest
    http://www.cheapbatterypacks.com/ will make one for you if you send them
    a diagram of how it is wired. My Dewalt pack comes apart with 3 torx
    head screws pretty easy. It would be cheaper to just buy the individual
    cells and solder it together yourself. That web site sales both packs
    and the cells for you to do it yourself.
    Chris W
    Gift Giving Made Easy
    Get the gifts you want &
    give the gifts they want
    http://thewishzone.com
  4. Nikki
    Nikki Guest
    I think I will order from cheapbatterypacks but I have a question from
    you guys. My battery pack is 18.5 volts I took it apart and there is 15
    cells of 1.5 volts each that would add up to 22.5 volts so why does my
    volt meter say 18.59 across all the cells
  5. John Fields
    John Fields Guest
Similar Threads
Loading...
