Rearranging an array in the arduino
Discussion in 'Microcontrollers, Programming and IoT' started by hussain.omail, Apr 29, 2015.
  1. hussain.omail
    hussain.omail
    6
    Feb 15, 2015
    I am taking an array input called attempt[] from the user then according to the value of attempt I rearrange another array called user[] but the problem here is that I am able to do this only one time while I am suppose to be able to do that whenever I enter a value from the keypad
    I am not sure if the problem is from the way I monitor the code using the serial or from the code itself
    hope u can help me with that
    thanx,
    #include <Keypad.h>
    const byte ROWS = 4; // four rows
    const byte COLS = 3; // three columns
    char keys[ROWS][COLS] = {
    {'1','2','3'},
    {'4','5','6'},
    {'7','8','9'},
    {'*','0','#'}
    byte rowPins[ROWS] = {2, 3, 4, 5}; // connect to the row pinouts of the keypad
    byte colPins[COLS] = {8, 7, 6}; // connect to the column pinouts of the keypad
    Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    char attempt[5]={0,0,0,0,0};
    int load1=2;
    int load2=4;
    int load3=7;
    int load4=8;
    int load5=12;
    int user[5]={load1,load2,load3,load4,load5};
    int i=0;
    void setup() {
    Serial.begin(9600);
    void loop() {
    char key = keypad.getKey();
    if (key != NO_KEY) {
    switch(key)
    case '*': i=0;
    break;
    default:{ attempt=key;
    if (attempt == '1'){
    user= 2;
    else if (attempt == '2'){
    user= 4;
    else if (attempt == '3'){
    user= 7;
    else if (attempt == '4'){
    user= 8;
    else if (attempt == '5'){
    user= 12;
    i++;}
    Serial.println(user[0]);
    Serial.println(user[1]);
    Serial.println(user[2]);
    Serial.println(user[3]);
    Serial.println(user[4]);
  2. FenTrac
    FenTrac
    May 26, 2015
    It appears that when you are assigning values to the array "int user[5]", that you are not specifiying the position of the value in the array.
    For example, should "if(attempt == 5) { user = 12;}" be something like "if(attempt == 5) {user[4] = 12;}" ?
