D
Dan Lenski
Hi all,
I'm playing around with a wireless router that has a TTL-level serial
port and trying to figure out an easy way to convert it to RS-232
without having to wait for a Maxim IC to come in the mail. While
hunting around for tricks to doing this, I came across one that seems
really impressive:
http://www.botkin.org/dale/rs232_interface.htm
The "receive" portion seems straightforward: just use an n-type MOSFET
and pull-up resistor to switch the TTL output between 0 and 5V.
But the "transmit" portion seems a little dodgy: first, it relies on
the computer always putting out +12V on the RTS pin, which apparently
is the default state of that pin if you leave hardware flow control
off. And secondly, it can can only transmit 0V or +12V. And according
to the RS-232 standard, 0V is undefined (+-3V are the thresholds).
The guy who came up with this says that it has worked with every
laptop, desktop, and PDA serial port that he's tried. Kind of cool...
so I guess that most computers interpret a 0V signal as a logical 1, as
would be required to make this scheme work? Has anyone used this
simple level converter? How'd it work for you?
Dan Lenski
really impressive:
Dan Lenski
