really low power transistors
Discussion in 'Electronic Basics' started by [email protected], Dec 19, 2008.
  1. Guest
    Anyone recommend any NPN transistors with around 0.1-0.3VBE sat. ?
    I did a mouser search but apparently Vbe sat. isn't a commonly
    specified parameter... ?
    Michael
  2. ian field
    ian field Guest
    Either the OP has got the terms mixed up or wants a germanium transistor.
  3. Guest
    Yeah, low power isn't necessarily equal to low Vbe_sat, but I figured
    a 0.1Vbe_sat transistor wouldn't be an output transistor in a 100W
    audio amplifier anyway...
    Thanks.
    Michael
  4. ....
    What a coincidence - I just subscribed here to ask that exact question.
    Well, my question's a little more complicated, so I'll do another
    thread for it.
    As to your question - I found low Vcesat ... oh, wait - you wanted low
    V_be_sat. Or did you? Anyhow, ON Semi has SMT BJT's down to 50 mv Vcesat:
    http://www.onsemi.com/PowerSolutions/parametrics.do?id=808
    HTH,
  5. Phil Allison
    Phil Allison Guest
    "John Larkin"
    ** You didn't read the question.
    The trolling fool wants Vbe sat to be impossibly low.
    .... Phil
  6. Jamie
    Jamie Guest
    When I don't have that info in front of me, I usually go for a
    low Vceo range, the Vsat is normally lower.
    Your search is average for a unit in the 20 Vceo range.
    http://webpages.charter.net/jamie_5"
  7. Eeyore
    Eeyore Guest
    Vbe ?
    Do you mean Vce ? Shouldn't be a problem. 2N4401 2N4403 are very low
    IIRC. Mind you @ what current ? You're really not supplying enough info.
    Graham
  8. Eeyore
    Eeyore Guest
    You're talking nonsense.
    Graham
  9. Eeyore
    Eeyore Guest
    Yup 50mV is no trouble.
    Graham
  10. Hammy
    Hammy Guest
    Yes Zetex has about the best low VCE sat BJT's that I've found. The
    FMMT491 and FMMT618 to name two.
    Onsemis got a couple too the NSS40201LT1G and the NSS40301MZ4 they're
    a little pricey though.
  11. Guest
    Yes, that.
    No, not that.
    Ah.
    Mr. Larkin had an interesting idea. If I wanted to say power a boost
    converter (0.1 V to 1V) could I just feed the 0.1V to the base of my,
    eh, 2N3904 NPN and it would work (at just incredibly low efficiency,
    since it's not in saturation)?
    Michael
  12. Guest
    No.
    @ < 100 mA. Not expecting much @ 0.1V.
    Actually the 0.1V was kind of optimistic, come to think of it...
    Michael
  13. krw
    krw Guest
    Vbe with collector open?
  14. Guest
    Funny. I would have thought they are common. Guess I was wrong.
    Anyhow... I was thinking of making some sort of super-tiny electric
    generator (basically just a magnet loosely moving inside a coil of
    wire), and boosting that up to, oh, 1 volt or so, to light up an LED.
    Another challenge would be to rectify the tiny current... guess I
    can't use normal diodes (0.7V drop... oh well...)
    Michael
  15. ehsjr
    ehsjr Guest
    No, it wouldn't work at all, unless what you have in
    mind is different than what you seem to be saying.
    Give us a schematic of what you are thinking about.
    Ed
  16. Guest
    Homemade shake-generator (plastic can, coils of wire outside, magnet
    inside), bridge rectifier (Schottky?), capacitor, boost converter, LED
    Michael
  17. Sjouke Burry
    Sjouke Burry Guest
    I have done what you intended, removing the magnet/coil
    assembly from broken harddisks, and attaching 2 leds
    antiparallel to the coil ends.
    No need for rectifying, or boosting, just wiggle the coil
    were it used to be, and the leds will light just fine.
    Also interesting is, to shortcircuit the coil, and try to move
    it, it acts as if inserted in syrup.
    If you want more voltage from it use a small transformer.
    using the primary as output, you get all the voltage you want.
  18. Jasen Betts
    Jasen Betts Guest
    get a stronger magnet, and/or use more turns in the coil.
  19. Eeyore
    Eeyore Guest
    Well you can't do that with silicon (look at Vbe vs Ic)and you may have some
    trouble finding germanium devices.
    Graham
  20. Eeyore
    Eeyore Guest
    Read up on device physics !
    Put more turns on the coil. Easy. And use Schottky diodes.
    Graham
