Realization of an audio amplifier ..
Discussion in 'Electronics Homework Help' started by BuonBoy, Apr 6, 2013.
  1. BuonBoy
    BuonBoy
    Apr 6, 2013
    Hi!
    I'm trying to create an audio amplifier to use with two speakers 4ohm/8Watt each.
    As a power supply for the amplifier, I would use a Switching power supply ranging from 5V-3.8A and to a maximum of 24V-1.5A.
    If it works, I will present the pSpice schematic for an university exam :rolleyes: the exam plans to design an audio amplifier with 3-stage ...
    thank you!
  2. Merlin3189
    Merlin3189
    250
    69
    Aug 4, 2011
    If you have two speakers of "4 Ohm/8 Watt each", what is the maximum power output?
    What is the efficiency of the power amplifier stage you plan to use?
    So what power do you need to be able to supply?
    Alternatively, just design the amplifier, then calculate its power needs and then specify the power supply. If this turns out to be inconvenient, you could go back and modify your design in an iterative development process.
Similar Threads
Loading...
