Real Time OS Program Code based ARM Development Suite
Discussion in 'Microcontrollers, Programming and IoT' started by limesp, Apr 22, 2013.
  1. limesp
    limesp
    Apr 22, 2013
    Hi All,
    I am new to Real Time OS. Can anyone explain the code stated as below to me in details?
    First part:
    OS_STK MainTaskStk[MainTaskStkLengh];
    OS_STK Task0Stk [Task0StkLengh]; // Define the Task0 stack
    OS_STK Task1Stk [Task1StkLengh]; // Define the Task1 stack
    OS_STK Task2Stk [Task2StkLengh]; // Define the Task2 stack
    Second part:
    #define rGPKCON0 (*(volatile unsigned *)(0x7F008800))
    #define rGPKCON1 (*(volatile unsigned *)(0x7F008804))
    #define rGPKDAT (*(volatile unsigned *)(0x7F008808))
    #define rGPKPUD (*(volatile unsigned *)(0x7F00880C))
    void Port_Init(void)
    rGPKCON0 = (rGPKCON0 & ~(0xffffU<<16))|(0x1111U<<16);
    rGPKPUD = (rGPKPUD & ~(0xffU << 8))|(0x00U<<8);
    void Led_Display(int data)
    rGPKDAT = (rGPKDAT & ~(0xf<<4)) | ((data & 0xf)<<4);
    void Task2 (void *pdata)
    Port_Init();
    while(1)
    OSPrintf("this is from task2\n");
    Led_Display(0x9); // 1001
    OSTimeDly(OS_TICKS_PER_SEC/4);
    Led_Display(0x6); // 0110
    Third part:
    - How to create Task 3?
    Fourth part:
    - There are four leds in hardware. How led blinking based on Task0,Task1 and Task2 from this program code?
    Attached is the whole program code used in ARM Developer Suite.
    Appreciated and Thanks.
