Reading Pulsewidth
Discussion in 'General Electronics Discussion' started by microchipdip1, Dec 20, 2010.
  1. microchipdip1
    microchipdip1
    Dec 20, 2010
    I am new to the forums. I am trying to read a signal with a microchip. However the microchip has a max input of 5v. The incoming signal is a square wave (0v, 12v). At the end of a hi pulse, it spikes to 40volts or even more. Id really appreciate it if someone could tell me what components I would need to put in that circuit to drop it down to (0v, 5v), and block out that spike.
    Steve
  2. (*steve*)
    25,480
    2,828
    Try something like this:
    [​IMG]
    The 10K resistor limits the current. The 2 diodes clip any voltage higher than 5 or lower than 0) The additional 1k resistor limits the current through the protection diodes on the microchip should a really large spike come along,
  3. microchipdip1
    microchipdip1
    Dec 20, 2010
    Can you point me to the most suitable and preferably cheap diodes that will do this? I am inept with electrical components. I only know how to program the microchip. Would TVS diodes be suitable?
  4. (*steve*)
    25,480
    2,828
    Almost any diode will work in that circuit. The only exception would be zener diodes rated at significantly less than 5V -- in fact, making the bottom one a 5.1V zener has some advantages (but I digress)
    1N400x would be fine (use whatever is cheapest). If you have some 1N4148's or 1N914's or almost anything.
    A 40V spike will give you about 4mA through the diode. The reverse voltage will never exceed about 5V. Switching speed may be an issue, so I might prefer the small signal diodes if the spikes are especially fast (rise time) or high in energy.
    Where is this input coming from (it's not the ignition coil of a car is it?)
