reading Power Dissipation graphs
Discussion in 'Electronic Basics' started by [email protected], Mar 24, 2008.
  1. Guest
    I'm reviewing the datasheet for the LM1875.
    Page 4, upper-left, has a Power Dissipation vs. Power Output graph for
    a 4-ohm load.
    For +/-30V, to get 30W out, power dissipation is given as 47W.
    What is meant by "power dissipation"?
    Is this total heat generated, for heatsink load calcs?
    Is this the total power consumed ( = the power delivered by the power
    supply)? If so, then the chip is 30W / 47W = 64% efficient, right?
    Michael
  2. Phil Allison
    Phil Allison Guest
    ** Yep.
    ** Nope.
    ** No.
    The LM1875 is not usable at 4 ohms with more than a +/- 20 volt supply -
    as it has in internal current limit of 4 amps.
    30 watts into 4 ohms = 11 volts rms = 15.5 volts peak.
    So with a +/- 30 volt supply, the IC is only able to use half the available
    supply voltage with a 4 ohm load.
    Makes it very INEFFICIENT !!
    It will go into thermal shutdown and/or gross distortion with a 4 ohm
    speaker load.
    ........ Phil
  3. In <>,
    That is true.
    No, efficiency in this case is 30W / (30W + 47W) or 39%.
    - Don Klipstein ()
