Reading Current of Solenoids
Discussion in 'General Electronics Discussion' started by Omar Zeyad, Dec 18, 2015.
  1. Omar Zeyad
    Omar Zeyad
    6
    Dec 18, 2015
    Hi Guys,
    I'm having some issues with a circuit that I've created to measure the current going through a solenoid.
    Basically, I'm using AD8202 to measure the current being supplied to a load (solenoid),
    Here is a small description of the circuit.
    The expected current that will go through the solenoid is about 2 Amps! I already tested the circuit with a power resistor and I was able to read the current through PIN 5. but everytime I test the circuit with the real load (the solenoid). the AD8202 gets blows!!
    What do you guys think? would this have to do with the back EMF from the solenoid? or is my design have an issue?
  2. davenn
    davenn Moderator
    13,799
    1,940
    duke37 likes this.
  3. Omar Zeyad
    Omar Zeyad
    6
    Dec 18, 2015
    I was thinking of adding a diode to the solenoid (to drain the back EMF). but I was afraid that it will change the property of the circuit that I'm testing.
    Any idea if there is another chip that can handle higher voltages?
  4. Omar Zeyad
    Omar Zeyad
    6
    Dec 18, 2015
    I guess everyone is out watching the new star wars movie!!:p:D
  5. GPG
    GPG
    452
    66
    Sep 18, 2015
  6. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    Your circuit does not have the clamp diode so excessive voltage is generated on switch off.
    Having a higher voltage chip may not work since the solenoid can doubtless produce several hundred volts if turned off fast enough.
  7. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    You need to have a completely separated power supply for the solenoid, so the back emf does not enter the chip.
  8. davenn
    davenn Moderator
    13,799
    1,940
    his circuit and the datasheet circuit already show that fact Colin !!
    a snubber diode is still required tho to stop the large back EMF voltages entering the IC sense input pins
    D
  9. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    How can a large emf develop across a 100 milli ohm resistor ??????
  10. GPG
    GPG
    452
    66
    Sep 18, 2015
    The ground is shared so back emf is impressed on the sense terminals relative to com.
  11. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    If the two have completely separate power supplies, no extra protection is needed.
  12. GPG
    GPG
    452
    66
    Sep 18, 2015
  13. Omar Zeyad
    Omar Zeyad
    6
    Dec 18, 2015
    Thank you guys, I'm going to try adding a clamp diode over the load.
    I'm almost certain it's the back EMF, I tested the circuit with power resistors and didn't have an issue. but I did have the same problem when using solenoids.
  14. Minder
    Minder
    3,066
    657
    Apr 24, 2015
    I am wondering why you need to measure the current as if the solenoid is DC the current is predictable based on the resistance of the coil?.
    If it is a case of confirming the current is actually present, then you do not need an A/D conv to do this?
    M.
  15. Omar Zeyad
    Omar Zeyad
    6
    Dec 18, 2015
    I'm validating a circuit that powers up the solenoids (which are current controlled).
  16. Minder
    Minder
    3,066
    657
    Apr 24, 2015
    If I read that right then all you need is actual current confirmation, not the value itself!
    M.
  17. Omar Zeyad
    Omar Zeyad
    6
    Dec 18, 2015
    Well, the current supplied to the solenoid might change.
