Reading ASCII CSV data from an External Module to Arduino Serial Ports
Discussion in 'Microcontrollers, Programming and IoT' started by Lei Reyes, Aug 11, 2015.
  1. Lei Reyes
    Lei Reyes
    60
    Jul 2, 2014
    Hi everyone !
    I have a Power analyzer module here:
    http://www.e-gizmo.com/KIT/poweranalyzer2.html
    that can analyze the power statistics such as
    • Real Power
    • Apparent Power
    • Reactive Power
    • Fundamental & Harmonic Power
    • Power Factor
    • Volt rms
    • Amp rms
    • Watt-hr
    It uses UART Communication so that I can connect it directly to a PC and read its values to my VB Program below:
    Code:
    Public Class frmEMII
        Dim serialdelay As Integer
        Private Sub tmrRx_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles tmrRx.Tick
            Dim rxstring As String
            Dim RX() As String
            Dim temp() As String
            'Timer2.Enabled = False
            If SerialPort1.BytesToRead > 1 Then
                serialdelay = serialdelay + 1
                If serialdelay > 3 Then
                    rxstring = SerialPort1.ReadExisting
                    rxstring = rxstring.Replace(Chr(13), Chr(13) + Chr(10))
                    serialdelay = 0
                    RX = rxstring.Split(",")
                    'OK must be the first in splitted string
                    If RX(0) <> Chr(2) + "OK" Then
                        lblAlarm.BackColor = Color.Red
                        Exit Sub
                    End If
                    lblAlarm.BackColor = Color.Black
                    lblVer.Text = RX(1)
                    temp = RX(2).Split(".")
                    lblVRMS.Text = temp(0)
                    lblVrms1.Text = temp(1)
                    temp = RX(3).Split(".")
                    lblIrms.Text = temp(0)
                    lblIrms1.Text = temp(1)
                    temp = RX(4).Split(".")
                    lblRP.Text = temp(0)
                    lblRP1.Text = temp(1)
                    temp = RX(8).Split(".")
                    lblPF.Text = temp(0)
                    lblPF1.Text = temp(1)
                    lblS.Text = RX(5)
                    lblQ.Text = RX(6)
                    lblF.Text = RX(11)
                    lblH.Text = RX(10)
                    lblFQ.Text = RX(12)
                    lblWHr.Text = RX(13)
                    lblIT.Text = Sec2Time(Val(RX(14)))
                    lblTemp.Text = RX(9)
                End If
            Else
                serialdelay = 0
            End If
        End Sub
        Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
            SerialPort1.Open()
        End Sub
        Private Sub InitMeterToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles InitMeterToolStripMenuItem.Click
            SerialPort1.Write(Chr(2) + "M2" + Chr(3))
        End Sub
        Private Function Sec2Time(ByVal Time As Integer)
            Dim sec, min, hr As Integer
            Dim s, m, h As String
            hr = Int(Time / 3600)
            min = Int((Time - Int(hr * 3600)) / 60)
            sec = Time - Int(hr * 3600) - Int(min * 60)
            s = sec.ToString
            m = min.ToString
            h = hr.ToString
            If s.Length < 2 Then s = "0" + s
            If m.Length < 2 Then m = "0" + m
            If h.Length < 2 Then h = "0" + h
            Return (h + ":" + m + ":" + s)
        End Function
        Private Sub btnClear_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnClear.Click
            SerialPort1.Write(Chr(2) + "R" + Chr(3))
        End Sub
        Private Sub ExitToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ExitToolStripMenuItem.Click
            SerialPort1.Close()
            End
        End Sub
        Private Sub OFFSETCalToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OFFSETCalToolStripMenuItem.Click
            If MsgBox("Calibrate Offset. Are you sure?", MsgBoxStyle.YesNo) = MsgBoxResult.No Then Exit Sub
            If MsgBox("Remove ACV jumper and press OK..", MsgBoxStyle.OkCancel) = MsgBoxResult.Cancel Then Exit Sub
            tmrRx.Enabled = False
            SerialPort1.ReadExisting()  'clear buffer
            SerialPort1.Write(Chr(2) + "O" + Chr(3))
            Do
                Application.DoEvents()
            Loop Until SerialPort1.BytesToRead > 1
            MsgBox(SerialPort1.ReadExisting, MsgBoxStyle.OkOnly)
            tmrRx.Enabled = True
        End Sub
        Private Sub MenuStrip1_ItemClicked(ByVal sender As System.Object, ByVal e As System.Windows.Forms.ToolStripItemClickedEventArgs) Handles MenuStrip1.ItemClicked
        End Sub
        Private Sub lblVRMS_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles lblVRMS.Click
        End Sub
        Private Sub lblRP_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles lblRP.Click
        End Sub
    End Class
    By Default, the Module outputs the data in ASCII CSV Format Stream, like this;
    Example CSV output stream:
    [STX]OK,1000,231 .49,0.21 6,34.56,49.65, -37.1 1 , -22.93,0.6961 ,40.07,0.03,34.53, -37.1 1 ,1 .475,987[ETX]
    This is the equvalent values for:
    [STX]STAT,VERSION,VRMS,IRMS,PREAL,VA,QAVERAGE,QINSTANT,PF,TEMPERATURE,PHARMONIC,PFUNDAMENTAL,PQFUNDAMENTAL,WATTHR,INT[ETX]
    The VB Program Works. However, I want to connect the Power Analyzer Module to my Arduino UNO RX/TX Ports, but I do not know how to do the following though I am still a newbie to arduino:
    1. Program the arduino to read the values coming from the power module up to the Arduino RX/TX Ports
    2. Convert these ASCII CSV values into INT values so that I can store them to different arduino program variables.
    the VB Program I am using, and the Manual for the Power Analyzer Module is given also in the above link
    Thanks Guys !
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Luckily for you ascii is simply a numerical representation for the characters you see.
    You can either subtract 48 from the character to get the 'number' as long as the value of said character is between 48 and 57... Or you can use loop through a 'case select' statement and go through the string character by character to store the appropriate values in the variable you require.
    There should always be a fixed number of commas, each time you encounter a comma, move to the next variable ;)
