Reading a ruler help, 1.2 or 1.02
computer-joe
Oct 6, 2016
29
Oct 6, 2016
29
help! i need some ruler help,
Im making a project on photo shop. I had to measure a paper cover i own
it measures 1.something by 1.something
i need to put that in photoshop, but the problem is i don't know the correct reading.
Would it be 1.02 or 1.20
here is a picture of that
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Well,
Since you asked,(it is quite obvious to most people),
here is a simple way to deal with these kind of linear scales:
Each CM(biggest bars) is divided into 10 equally spaced smaller bars with one medium sized one in the middle.
It should be interpreted like so:
Each small bar is 1/10 of a CM (0.1CM).
The mid bar is 0.5CM.
That would work for all types of linear scales.
People used to CM scales take that(decimal system 1/10) to be an obvious thing.
When they switch to Inches they have a problem understanding the power of 2 system(1/2,1/4 1/8,1/16 etc.)
Isn't it about time to throw away that ridiculous inch system ?
Who in the world still uses it ,(USA and...)?
Apart from the difficulty of switching ,why ?
Bluejets
Oct 5, 2014
6,921
Oct 5, 2014
6,921
Ah yes, but, it's quicker to say "knock off an extra thou" than it is to say" knock off an extra zero point zero two five millimetres". :p
Edit: for the machinists out there ....:)
hevans1944
Hop - AC8NS
Jun 21, 2012
4,880
Jun 21, 2012
4,880
Yeah, I have trouble even seeing those itsy bitsy teeny weeny marks on a steel scale that is marked off in 1/64" increments. And it seemingly gets worse when that inch scale is only divided into fifty linear increments instead of sixty-four. I usually keep a set of vernier calipers with a dial indicator or a digital readout handy to verify that I've read the scale correctly.
