Re: Phonetic Alphabet Tables
Discussion in 'Electronic Repair' started by Peter Aberrant, Apr 19, 2004.
  1. Trevor Day
    Trevor Day Guest
    Agreed, and ( some are definitely not going to like this:) semaphore
    is still used in the RN but largely between the RN and RFA to pass
    personal messages between COs during refuelling. This won't go on
    forever as semaphore is no longer a compulsory part of the signallers
    trade (unlike Morse code) but, as long as there are those who want to
    learn it, there will be an avenue for its use.
    Trev
  2. Geoff
    Geoff Guest
    I quite agree. I too doubt that Lifeguards in the UK know landing
    signals, but I would expect that Coastguards and RNLI folk and possibly
    USCG to know them. Yotties who have done the RYA qualifications should
    have at least seen landing signals and they are fairly self evident in
    their meaning.
    YG
  3. Brian Reay
    Brian Reay Guest
    My, my. We are touchy tonight.
    All I said was "removal"
    73
    Brian
    G8OSN
    www.g8osn.org.uk
    www.amateurradiotraining.org.uk for FREE training material for all UK
    amateur radio licences
    www.phoenixradioclub.org.uk - a RADIO club specifically for those wishing
    to learn more about amateur radio
  4. Rod Speed
    Rod Speed Guest
    And you dont need to be able to read morse at anything like
    6wpm to do that, and dont need to be able to read it at all when
    the NDB receiver decodes it itself and displays it in text format.
    Wrong again.
    There is no morse test for cpl anymore
    in any of the main first world countrys.
  5. Rod Speed
    Rod Speed Guest
    Fantasy. I just asked if semaphore was used anymore FOR FUN.
    AND I clearly said that a few loons may well be doing that.
    After all, some do some quite remarkably silly things
    FOR FUN like train spotting, bird spotting, etc etc etc
    and it wouldnt surprise me in the slightest if someone
    is still foisting it on kids in the sea scouts etc even now.
    Why instead of those light systems whatever they are called ?
  6. Rod Speed
    Rod Speed Guest
    Oh cheap arsehole.
    No such animal.
    Pity that the context was obvious relevant
    with that question of stuff done FOR FUN.
    More fool you. Threads frequently drift away from that is
    in the subject and even someone as stupid as you should
    have noticed that was true with the post you replied to.
    No such animal.
    Pathetic, really.
    Even you should be able to bullshit your way out of your
    predicament better than that pathetic effort, arsehole.
    Good Riddance!!!
  7. Rod Speed
    Rod Speed Guest
    Go and **** yourself.
    Wrong. As always.
    Go and **** yourself. Again.
    Not one pair of which wouldnt have seen worse than that.
    Completely irrelevant.
  8. Rod Speed
    Rod Speed Guest
    You get to like it or lump it, bog trotting arsehole.
    That you're a terminal fuckwit most likely.
  9. Rod Speed
    Rod Speed Guest
    Says he carefully deleting from the quoting what was said.
    Another flagrantly dishonest arsehole.
    Pity the principle is completely different. Landing signals DO
    NOT spell out the message letter by letter. Semaphore does.
    Thats not what you said initially, you flagrantly dishonest arsehole.
    So the 'principal' is nothing like the same. The ONLY similarly
    is that arms and flags are normally used and flags arent usually
    used with landing signals, normally just arms.
    What the **** is the point in repeating what I already said, fuckwit ?
    You were always just plain wrong with your original claim that there
    is any 'principal' in common between semaphore and landing signals.
  10. Rod Speed
    Rod Speed Guest
    Nothing to do with semaphore, fuckwit.
    Just another terminally silly pommy wank.
    Pathetic fuckwit hasnt even got the remotest concept of
    geography right. No one around me uses euros, bogtrotter.
  11. MC
    MC Guest
    sigh.. another entry into my killfile.
    (and of course Rod will reply with another predefined insult)
  12. Geoff
    Geoff Guest
    This is an excellent example of somebody who, when failing in debate,
    resorts to the profane.
    YG
  13. Geoff
    Geoff Guest
    [email protected]_band_cb_is_here.eircom.es.it.net (zpk) wrote in
    So? Who cares in the slightest what you say - although at least you do not
    decend into profanity when your argument fails, unlike a certain "Mr
    Speed".
    YG
  14. Trevor Day
    Trevor Day Guest
    I am just telling you how it is. There is no particular reason for you
    to believe me other than understanding that I would not post garbage
    under my own name and email address. I will correct matters of fact
    where I have personal expertise (when I can be bothered) similarly, I
    will not post information unless I believe it factual.
    What you do with the info I provide is entirely your problem but don't
    expect me to waste time discussing it with you.
    Trev
  15. Binary Era
    Binary Era Guest
    And when profanity fails top work, he gives you.....more profanity!
  16. Rod Speed
    Rod Speed Guest
    Some gutless fuckwit pom desperately cowering behind
    just the shit you'd expect from a desperately cowering gutless fuckwit pom.
  17. Jeff
    Jeff Guest
    Probably because there is a man standing there with flags in
    his hand already. Flags (not semaphore) are used to control
    the passing of ropes, pipes etc between the 2 ships. You
    may ask why not use radio but I guess this can be detected
    by an enemy.
    Jeff
  18. Rod Speed
    Rod Speed Guest
    Crap, not on that stupid '( some are definitely not going to like this:)' claim.
    I know that claim is stupid shit.
    No one has any way of knowing if that is invented or not
    and plenty are stupid enough to make very spectacular
    fools of themselves even when they do use their own name.
    That particular stupid '( some are definitely not going to like this:)'
    claim aint even a matter of fact. Its just your stupid claim.
    You're beliefs have always been and always will be, completely
    and utterly irrelevant with that particular stupid claim.
    No problem for anyone except you, wanker.
    How odd that you did, fuckwit.
  19. Rod Speed
    Rod Speed Guest
    Even a stupid desperately wanking stupid pom should be able to
    bullshit its way out of its predicament better than that pathetic effort.
  20. Rod Speed
    Rod Speed Guest
    Some gutless fuckwit desperately cowering behind
    just what you'd exect from a desperately cowering gutless
    fuckwit thats got done like a fucking dinner, as always.
