N
N Cook
Tam/WB2TT said:I have never seen a house here in the US wired with stranded wire, except
for one built in 1906. Generally #14 solid copper. BTW the 3 wire UK plug
reminds me of what is used on a clothes dryer or stove here. Would you
actually use one of these on a lamp?
Tam
We have no choice in the matter, by law, we can use 1,2 or 3 amp fuses
inside these plugs but thats the only choice
The USA cannot have the equivalent of RoSPA (Royal Society for the
Prevention of Accidents), AFAICS none of the USA ones have child preventers
on them unless the mouldings on the wall outlets preclude that eventuality
of small fiongers touching both pins.
The other notable difference is the insulated pins that have been necessary
refinement, again by law, for 20 years or so
You can just see the orange plastic bits extending up the brass pins on the
first pic on this wiki and the black bits on the one lower down on
http://en.wikipedia.org/wiki/BS_1363
The phase and neutral pins on modern plugs have insulated bases to prevent
finger contact with pins and also to stop metal sheets (for example, fallen
blind slats) from becoming live if lodged between the wall and a partly
pulled out plug. A downside to this prong insulation is that it may
contribute to damaged sockets not making good contact with the prongs, which
may even melt the latter. No such problems exist with healthy sockets.
as an aside someone told me that per million houses there are more house
fires in the USA due to wiring faults than any other country, partly due to
a lot of timber construction and partly due to the higher current for a
given KW of power transfered - is that the case?
