E
Eeyore
Bill said:Impedance for an un-loaded pair varies with frequency. So at DSL
frequencies the impedance is 100 to 110 Ohms.
But for telephone use They preferred to use loaded
pairs and they were designed to be 900 Ohms. And the phone should be a
reasonable match to the line to minimize refections which bother the users as
echoes
The transformers in some sets was not an isolation transformer but a
hybrid and matching transformer.
The carbon mic. used in the old phones
was powered from the line. And many of the newer phones derive power from the
line. So isolation can't be used.
Phil said:"Bill Janssen"
** Huh ??
Audible echoes on a few miles of twisted pair ???
Phil said:"Lostgallifreyan"
** Oxygen thieves like this anencephalic turd need shooting.
Eeyore <rabbitsfriendsandrel said:Unfortunately has has NO CLUE about the characteristic impedance of twisted pair
cable as used for telecoms.
http://en.wikipedia.org/wiki/Twisted_pair#Unshielded_twisted_pair_.28UTP.29
"UTP is also finding increasing use in video applications, primarily in security
cameras. Many middle to high-end cameras include a UTP output with setscrew
terminals. This is made possible by the fact that UTP cable bandwidth has
improved to match the baseband of television signals. While the video recorder
most likely still has unbalanced BNC connectors for standard coaxial cable, a
balun is used to convert from 100-ohm balanced UTP to 75-ohm unbalanced."
*** 100-ohm balanced UTP ***
Graham
Eeyore <rabbitsfriendsandrel said:Quite so !
Absolutely not. About 100 ohms.
Via 'Post Office Telecommunications'.
He has made that evidently apparent.
Graham
tony said:I seem to remember from another time that Old Floyd worked for some
Alaskan phone company..
Anyways what was the original question .. seems to have fallen off the
news server?...
Eeyore <rabbitsfriendsandrel said:A slightly obscure question as to effectively (not sure if the OP realised)
whether
impedance or voltage matching was important. Needless to say, many IDIOTS think
everything audio HAS to be 600 ohms which is an irrelevant ancient standard
anyway
but lingers on in the minds of the long brain-dead.
Here's the original.
" I am looking for some 1-to-1 matching transformers to connect varioua
audio devices to my PC. I usually get noises and hum.
These line matching transformers are not so cheap at about £6 or 7
each.
Telephones seem to suppress line noise and hum rather well so I
figure the components they use are probably of half-decent quality.
If I strip down some landline phones I 've got here, then will there
be a matching transformer in each one? Or is their technology
different now? "
Graham
In european specifications (for Finland etc..) I have seen this
that complex reference impedance Z = 270 + (750 //150 nF)
750 ohm
_____
270 ohm +--|_____|--+
_____ | |
--|_____|---+ +-----
150 nF
I'm waiting to see your guesses to *both* questions
Hint: both answers relay on the fact that the lines are straight analogue
from end to end.
**** Off already you Deadend Drifters..
All the OP needs is a preamp with audio controls between the PC and
whatever you cheap canabalistic fly by night wannabe engineers....
Roy Q.T.
[have tools, will travel]
I want to minimise any ground loop to reduce hum and other spuriae so
perhaps I should have said "isolating" transformer.
My aim is to take voice recordings made on various equipment and save
them to a PC. Some of the voice recordings are of telephone
conversations made onto tape. I would prefer to have fed the phone
signal direct to the PC but I get a lot of noise.
It's true that isolation is not important for a well-insulated telephone.
Interesting thread (not the childish abuse, the technical stuff!).
This is true ...
doesn't matter because the speed of light is so high, and that's true for
local calls but not for long distance ones.
These days there is packet delay to worry about as well. There are echo
cancellers but they're not perfect. Mismatches also affect loudness.
It's also true that differential amps are a cheap alternative to
transformers for the hybrid part. But I have definitely seen phones with
transformers in them in the past (the 80s).
And I have designed interfaces myself (for modems) that used transformers
A 10kV arc from a 2MV lightning strike *COULD* make it all the way into
the handset, and OUT of the perforations in the handset, through the
earpiece or mouthpiece, and hit the user.
This is ONE of the many reasons that isolation elements are
incorporated at VARIOUS locations in the system.
It isn't your Dad's AC fed two wire drill motor with an
un-phased power cord and metal case. It is, however, in close
(electrical) proximity (potentially) with lightning events, and that is
why arresting elements have been incorporated.
Most incorporations are overkill,
** Plus it would jump across the insulation barrier in a 600 ohm line
isolation tranny too !!
FUCKWIT !
