Re: Driving large numbers of LEDs
Discussion in 'LEDs and Optoelectronics' started by neon, May 17, 2008.
  1. neon
    neon
    1,325
    Oct 21, 2006
    the amount of LEDS to be used is depended on power available from 120V AC and a diode you can drive at least 90 or more in series asuming a 2.5v each. then you can add more and more as you wish until the wires burn up.
    LEDS unlike lamps the brightness sepends on current and a minimum of voltage present. i supose a triac and a photo triac interface can be used to vary the light output from the string of LEDS. i did something like this last xmas it is not as good as lamps though. good luck.
  2. Eeyore
    Eeyore Guest
    Fascinating. I know someone (family actually) intending to do something
    very similar.
    Graham
