Rca tv problem, can I do this for a fix?
Discussion in 'Electronic Repair' started by [email protected], Jan 4, 2006.
  1. Guest
    x-no-archive:yes
    I have posted about my 90's model RCA tv certain channels going out
    then coming back on. I can make them come back by jiggeling the rf
    connector in the back.
    I read something about somone taking a small guage wire and soldering
    the tuner shield to a ground to eliminate all the soldering. Since I am
    an inexperienced ciruit board solderer, would this be feasible to do?
    DO I understand that right? They soldered a wire from the metal tuner
    cover to a ground?
  2. Ralph Mowery
    Ralph Mowery Guest
    RCA had many problems with the solder. Especially around the tuner. You
    may have to take the top of the tuner and solder everything you see,
    especially the solder traces around the shielding can. Then put the lid
    back on.
  3. Guest
    x-no-archive:yes
    I have not taken this off yet. Is this a hard repair? Where and what is
    the sheilding can?
    I have noticed that wiggeling the rf connector makes thie picture come
    back.
    I really appreciate your help.
  4. kip
    kip Guest
    Wiggle it some more and it will break off..
    You will need a Mag Glass and fine tip iron to repair the shield.
    Now if you dont know what the shield is then take the TV to a repair shop.
    Do a Google on it....There is plenty of info there....
  5. Guest
    x-no-archive:yes
    Are you calling the shield the cover to the tuner?
    I have a gun not the pencil tip kind but I can get one.
    I have limited income due to a baby and would like to fix it myself.
    Plus the tv is very heavy.
    Since it gets better when wiggeling the rf connector, could this be the
    only problem?
  6. Guest
    x-no-archive:yes
    Wait, are you talking about the shield for the rf conenctor? I think I
    first misunderstood you. ou are saying repair the solder joints for the
    ground for the rf conenctor, right?
  7. kip
    kip Guest
    Do a Google....
    No ! I say if you wiggle the connector YOU will break it off.
    The tuner shield is the fault.....
    Like I said before you will need a fine tip Iron NOT a Gun type.
    This repair is beyond you ..Why not let a Pro repair it .
  8. Guest
    x-no-archive:yes
    Can you explain what the tuner shield is? (For my own knoweledge)
    I think I cna repair this with some help. I dont have alot of money to
    take it somewhere plus the thing weighs a ton.
  9. kip
    kip Guest
    R you unable to do a Google search ??
  10. Guest
    x-no-archive:yes
    I have done it but can only come up with bits and pieces of info. An no
    definition of "tuner shield"
    I appreciate your help!
  11. Guest
    x-no-archive:yes
    Would the soldering problem apply to me? My chasis number is: ctc169xxx
    The ones I read with this problem were ctc173xxxx to 183xxx.
    Could the sodler still be my problem?
  12. kip
    kip Guest
    Whats the CTC number of the TV...
    Search that number
  13. Guest
    x-no-archive:yes
    ctc169Js6
    I have been reading some more and it seems some have solved the
    probelem by just resoldering the bottom of the tuner shield to the
    board. AM I understanding that right?
  14. kip
    kip Guest
    Ok Pull out the Tuner remove the covers and get that Mag Glass out...
    Look for dry solder joints,these are not easy to do on the 169 tuners.
    Good Luck
  15. Guest
    x-no-archive:yes
    Why is it not easy to do ont he 169? The only picture I could find on
    the net was a 175 or so here: http://www.repairfaq.org/sam/rcatune.htm
    Does the 169 look like that?
    What exactly do you mean by a "dry" joint? Where solder has come off
    the board? (Like what happens in a cold joint as I call it.)
    Do I first need a de soldering tool to "desolder" the joint?
    I really appreciate your patience and help.
  16. kip
    kip Guest
    Ok...Enough.. Call a TV shop let them repair it.
    Its way over your head..
    ciao
  17. sofie
    sofie Guest
    stryped:
    OK.... you said you do not have enough money to have it properly repaired
    by a shop so I guess for sure that you do not have enough money to replace
    the television.
    I am not trying to say you are not capable of repairing things BUT due to
    the nature of you continued questions and lacking the proper tools and
    experience, it is my opinion that you are way out of your league here.
    Take it to a repair shop for a proper and SAFE repair or at the very least
    get a repair cost estimate so you can make an intelligent repair decision
    with facts instead of guesses. TAKE it to a shop for and estimate... a
    phone call will just be wild guesses.
    With a baby on the way.... you certainly want a SAFE repair and the baby
    needs a daddy..... so don't open it up unless you know what you are doing.
  18. jakdedert
    jakdedert Guest
    ....and in the meantime, tape it over with gobs of plastic tape so that
    it doesn't move (don't laugh--I've seen this...worse yet, I've seen it
    work--for a while, at least)
    jak
  19. Guest
    x-no-archive:yes
    Tape what?
    I have an extra tv but would liek to fix this one as it is a little
    bigger. I know to unplug the tv. I have a soldering iron. I just need a
    pencil tip. What else do i need?
  20. Guest
    x-no-archive:yes
    WHy do you say that?
