B
Brad
I have a RCA TV model 14F512T, ch M123SP (NO Schematic) in my TV service
shop with a vertical deflection problem. I replaced R409 1 ohm which was open
(in -12.6 source) and I replaced the vertical IC "IC301". Note: both +12.6
and -12.6 source (measured at source) are present, but still no vertical
deflection. Horizonal line is abt. 3/4 down from top of screen. When I open
the -12V circuit, in effect removing -12V source, the horizontal line is a
little above the middle. Yoke test revealed yoke is not shorted or open. I
tested several parts around "IC301".
Has anyone repaired this (or similar) model TV with this problem?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
