RCA Model DRD420RE Satellite Receiver burned SMPS
Discussion in 'Electronic Repair' started by Ron Novini, Feb 22, 2004.
  1. Ron Novini
    Ron Novini Guest
    Have a satellite receiver, RCA Model DRD420RE with burned components
    in the primary side of the switch mode power supply. These parts are
    badly burned and charred to the point of being unrecognizable. Need
    part ids for the following:
    Resistors R14109,R14110,R14113,R14112,R14103
    Diodes CR14101,CR14102 and CR14103.
    Transistor Q14100 (Can read P4NB50FP at bottom).
    Any help is appreciated. Thanks in advance Ron.
  2. ways
    ways Guest
    Hi Ron,
    I'm trying to to do the same repair on the DRD420RE I found sum values
    & part #'s . But still looking for the values or part #'s for
    CR14101,CR14102
    Here is what I have now if you find the values for CR14101,CR14102 or
    part #'s
    plz let me know...... Hope this helps.
    This is an attempt to list those parts that tend to fail in the RCA
    DRD22x and DRD4x0 series IRD's. The PC board silk screen designations
    were taken from a DRD420RE receiver, but should be the same for all
    models in these series.
    Abbreviations used:
    S.M. --- Surface mount part was used.
    F.R. --- Flame Resistant Resistor.
    ST --- ST Electronics. www.st.com (maker of the STI5500)
    Components on the Low Voltage Side of the Switcher.
    U14103 - LM7905 -5volt three terminal voltage regulator.
    L14102 - 22uh 200ma choke.
    CR14108 - ST BYW100-200 Fast Recovery Rectifier Diode.
    CR14104 - ST BYW98-200 Fast Recovery Rectifier Diode.
    Q24501 - TIP42A PNP Power Transistor (Must Use Insulator!).
    Zener - This S.M. Zener diode is located either next to the LNB tuner
    assembly, or inside of it. DRD22x used S.M. 33V 500mw, and DRD4x0 used
    S.M. 24V 500mw. Any value from 24V to 35V at 400mw to 1W should work
    fine.
    Components on the High Voltage Side of the Switcher.
    F14100 - 3 Amp 250V Axial Lead (Pigtail) Fast or SlowBlow fuse.
    R14102 - 3.3 Ohm, 1W 5% Metal Film F.R.
    R14113 - 100 Ohm, 1/4W 5% Metal Film F.R. -Blown Apart
    R14110 - 22 Ohm, 1/2W 5% Metal Film F.R. -Blown Apart
    R14112 - 1K Ohm, 1/4W 5% Metal Film F.R. -Blown Apart
    R14103 - 2.4k Ohm, 1/8W 5% Carbon or Metal Film Resistor.
    Q14102 - MPSA06 or MPSA05 NPN Transistor.
    Q14101 - MPS8599 PNP Transistor.
    Q14100 - ST STP4NB50FP N-Channel Enhancement Power Mosfet.
    CR14103 - 1N4148 S.M. Diode. -Blown Apart..Problem being not sure
    which is the cathode end. Can anyone help?
    The following three capacitors usually do not fail unless they are
    literally burnt off the board by the flames from R14112 and R14110. I
    will list them here in case you need them.
    C14100 - .033uf 50vdc S.M. ceramic capacitor.
    C14104 - .001uf 50vdc S.M. ceramic capacitor.
    C14105 - .22uf 63vdc mylar capacitor.
    Notes:
    DO NOT try to substitute for Q14100 ! I promise you will fail
    miserably, I know I did. Save your money and buy this part from
    RCA/Thomson, or from a ST rep. The Tr/Tf parameter for this part is
    what makes it unique, not the Rds, Vdss or any other parameters. It's
    how long it spends in that transition area. This part will be cool to
    the touch when running, never hot. (unplug your IRD before you touch
    it as 150vdc is present!) Just to prove this to myself I tried using a
    IRF840, a BUZ80A, and a NTE2946 from my parts collection. They all
    worked, for about 15 Seconds ! The parts become so hot after just that
    short a time I pulled the plug quick.
    Power Transistor Q24501 was of the plastic type on the DRD22x series,
    and RCA switched to the type with the Metal Tab, plus the addition of
    an insulating washer on later models like the DRD4x0 series. So if you
    do use a TIP42A with the metal tab Do Not Forget to insulate it from
    the heat sink with a mica or thermal pad. Also don't let the metal
    retaining clip touch the tab and short it out to the heat sink either.
    Use your ohmmeter when you are done replacing it to verify that there
    is No Continuity between the metal tab of the transistor and the heat
    sink.
    Here are the measured inductance values for switching transformer
    T14100 from a working DRD420RE. Part numbers on the side of this
    transformer read 15440720 and SEH2516-04. You must remove the
    transformer to obtain accurate readings. Most likely only 10% accurate
    anyway, so unless you measure something like 50% different, don't
    worry about it. I have never seen one of these transformers fail, but
    I just had to put this information someplace.
    ......Pins...........Measured Inductance.
    ....3 to 5..........1.03 MH
    ....1 to 2..........9.8 uh
    ....6 to 7..........4.2 uh
    ....6 to 10........17.7 uh
    ....8 to 9...........2.2 uh
