Rca ITC008 chasis
K
k dann
I,m trying to find a replacement for the Horizontal Output Transistor(HOT).
I replaced it with a 2SD1556, It worked for about 11/2 days; Then quit
again. Do not know the correct replacement; Because the numbers on the
transistor are unreadable. Any information would be greatly appreciated.
Thank you in adavance
S
Skype_man
Location # TL035? Part #230760. S2055 I beleive
NTE 2302. Sky.
A
Art
Suggest you determine the cause of it's failure, otherwise you better buy a
lot of them. Could be drive problem, PCC problem, even LOPT.
Similar threads
