RCA DTV306/307 60" picture cuts out.
Discussion in 'Electronic Repair' started by Jason D., May 28, 2005.
  1. Jason D.
    Jason D. Guest
    This DTV307 60" unit is hell to transport and is located nearly 30
    minutes drive from our shop out in country and is a big-time dog now.
    Original compliant was botchy picture traced to a spotty CRT, changed
    that. Unfortunely had to change all other two CRTs to stop the
    picture cutting out and ability to adjust TV to specs because TV
    already had long hours on it that CRTs had aged quite much so had to
    change all just to get it adjusted at all and hoped to stop that
    shutting down problem. The HV divider already replaced when we
    replaced CRTs.
    Shutting down or cutting out is either picture instantly winks out,
    sometimes had to power cycle tv by pressing button, in extreme case
    had to pull plug. No strange noises or fizzing smell.
    But customer still complains TV is doing same shutdowns when customer
    reset the picture settings to defaults, which setting that stops that
    problem is unknown because customer have not called back with reply to
    our questions.
    There is no bulletin on this particular problem. Any thing to look
    at, and this will be very diffcult to transport TV back to our already
    crowded shop. Sigh. Really NEED the tips very badly.
    Cheers, Wizard
  2. Jason D.
    Jason D. Guest
    Well?
    Soon within this week or next, we must go out and look at it.
    Transportation is a big PAIN and we had visited that unit several
    times in past and had to haul twice so...
    HELP?
    Cheers, Wizard
  3. Art
    Art Guest
    Pay attention to lousy solder connections every where on the main chassis
    assembly, including the stand up daughter board and the inter-connect
    between it and the processor board that connects at the rear apron. Agreed,
    these sets are an absolute Bow Wow to work on and fix. Thank the electronic
    gods that Thomson dumped them and their near cousins.<
