RCA CTC197AM - Horiz Adjust
Discussion in 'Electronic Repair' started by Troy Davis, Feb 6, 2004.
  1. Troy Davis
    Troy Davis Guest
    I've located the proper parameter in service mode to adjust the horizontal
    width of my TV, however, it doesn't affect the display when altered. The
    vertical sizing and centering parameters do work. I was using P5 which was
    indicated in the Service Manual for a CTC197 chassis. Any thoughts?
  2. David
    David Guest
    Your set may not have the option to adjust the pin or h-size depending on
    the size of the tv and feature level it was built with. I can guarantee
    that if it is smaller than a 27" it does not have any h adjustments
    available.
    David
